Hey all, I have a brake line that rusted a hole in it, anyone in the Lancaster that could help me out? I think I might have to go to the junkyard on this one
Brake Line rusted
Re: Brake Line rusted
JY not is going to help on this part!Originally posted by ZraceI think I might have to go to the junkyard on this one
Up this way(PA,NY, IN, OH, ect) the front hard lines from the master cylinder to the flex lines rust through where they pass from the engine compartment into the fender wells.
Best bet is to bend your own or get a set (you need to replace the other side ASAP too) from a member further south where salt/sand/cinders aren't used on a regular basis.
Had the same thing happen to my wifes car.
FYI - be prepared for long job concerning the driverside front hard line replacement, as it threads it way behind the fuel filter on the EFI engines.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Zrace, listen to what these guys are saying. They are 100% correct.ENFORCER - Midwest Festiva Inc., Iowa
#2 .....Cheesehead
#3 '91 White - Donor Car
#4 .....Montana Project
SOLD----Levistiva for $1500
Bought her back for $450
First time I did this, I bought a little extra line, and practiced bending by hand, it CAN be done, but a bender is oh so much better.
How about braided brake line? Flexible, no bending needed, think that might work? I have always wondered, then went ahead with hard line, perhaps slapping together a sort of hybrid, part hard line, part braided, tie it down real good so it cannot flex? hmmmm, I wouldn't recommend it here, but maybe I will try that one day...Contact me for information about Festiva Madness!
Look here www.ag384bn.bravehost.com/Braketips.htm for info on replacing Festiva brake line.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Good write up
EXCELLENT advice!!!!!Originally posted by jglutzIf you going to bend a new line and have a complete old line to use as a pattern....start in the middle and work to the ends.Contact me for information about Festiva Madness!
