Hello.
'96 Aspire, 161 K Km.
I'm replacing timing belt.
Is it necessary to remove crankshaft sprocket bolt ( main bolt )
to re + re timing belt.
If so, what's best way to get bolt out + in. i.e secure crank pulley from turning? Haynes says 80 - 85 ft-lb torque on bolt -- hopefully not necessary to remove.
Thanks,
-JS
Thanks,
-JS
