Ok,
So Friday morning I should be picking up my junkyard 5 speed. I am not familiar with these trannys at all "yet". But what I want to know is.. what is the common procedure by you fanatics here on transmission prep? Is there a cover of some sort I can remove to drain the old gunk out? How or can I clean/flush the thing out? Is there any seals, parts, pieces, whatever I should repair before I slap her on in?
What fluid do you guys fill your tranny with? I know it calls for mercon of some sort but are you guys using a good synthetic ATF or what? I really need a run down of what to do to clean/prep/prepair this junk yard trans. I used the search but no joy
Help a festy family member out!
