Originally posted by jglutz
Junkyard Tranny.... now what?
Also, you can check the level, which should be done periodically, by pulling the speedo cable from the trans. I know you should check it, that is how I lost the only trans to go in my car, it got a leak when I parked in dirt, and never noticed till it was too late....
Now I check that bugger like once a month
2.6qts? is that right? The computer at work tells me 5.2 but that wouldn't be the first time it was wrong.Originally posted by jglutz5 Speed....drain plug bottom right below the driver side output...Fill thru the Speedo cable port, right above the passenger side output...capacity, 2.6 qts.
^Did you notice how small that trans is ? 2.6 is all you need.Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
that 5.2 may be for the re-fill for an automatic trans after a fluid and filter change. i have never changed the fluid in an auto trans. so i don't know for sure.Originally posted by fordfest782.6qts? is that right? The computer at work tells me 5.2 but that wouldn't be the first time it was wrong.Originally posted by jglutz5 Speed....drain plug bottom right below the driver side output...Fill thru the Speedo cable port, right above the passenger side output...capacity, 2.6 qts.1960 willys pickup
1967 jeep cj5
1988 festiva
1989 festiva
1990 festiva for parts
1991 s-10
i've got a bad habit of only thinking in quarts,i forget there are smaller measurements also. C.R.S. is coming with my old age!!!!!Originally posted by FB715.2 pints = 2.6 quarts1960 willys pickup
1967 jeep cj5
1988 festiva
1989 festiva
1991 s-10
I have heard that it is better for your engine/transmission, to stick with the kind of oil as its used before, and using the same king can provide more benefits than switching to a 'better' oil. just something i heard.Originally posted by jglutz^^That's not a bad idea....It's you car....maybe thou, before you dump in the good stuff...you might want to put a few miles on with some cheap stuff or even transmission flush just to clean it out.Proud owner of 92L, 350KM, Home made muffler, sounds like a truck! 16 years without replacement of anything but filters! 5spd EFI, Anyone else's shifter look like its from a quarter-ton?
I think that info is more related to automatic transmissions then manual transmissions. But this is just my gut feeling and opinion, fordfest78 is not responsible for any damage done to your trans for putting in ultra super shift omg pwnzer fluid 5000 in your vehicle.Originally posted by IL4FestivaI have heard that it is better for your engine/transmission, to stick with the kind of oil as its used before, and using the same king can provide more benefits than switching to a 'better' oil. just something i heard.Originally posted by jglutz^^That's not a bad idea....It's you car....maybe thou, before you dump in the good stuff...you might want to put a few miles on with some cheap stuff or even transmission flush just to clean it out.
