before removing water pump pully bolts it helps to grab the alternator pully and pull strait up hard and break the water pump pully bolts loose. it keeps the pully from spinning while breaking the bolts loose.
Waterpump and alt belt replacement
The lower pulley is the crankshaft, the one on top is the camshaft. You have to get the crankshaft pulley off to get the bottom cover off. That is really the toughest part of the job, and it does not have to be too difficult, are you following the haynes manual?Contact me for information about Festiva Madness!
Did you remove the large nut in the center? Clearance, hmmmm, does it have a splash shield behind the psgr tire you can remove for clearance, I THINK I had one, and left it off....Contact me for information about Festiva Madness!
Ahhh, you need to immoblize the engine somehow, I thought I read putting in in 4th and mashing the brakes worked....anyone?
I USED to put a chain wrench around the pulley, a strap wrench might hold it. Haynes recomends pulling the starter and wedging a flathead screwdriver, wrapped in tape, into the flywheel. I could never get it to hold for me, though.
IF you can get ahold of an impact gun, a good one will zip it right off.....Contact me for information about Festiva Madness!
an adjustable wrench will probably strip it.......Originally posted by collegeboi View PostFUDGE, cant get that 1 big bolt off, tryed wd40, adjustable wrench argggggggg.
lefty loosey righty tighty right??????
been at it for an hour
please any help appreciated
Put some extra, errrr, butt into it.
Get a ratchet handle on it, or wrench, whatever, then, get another nice BIG wrench. Put the box end over the bolt, with the open end facing down, then slip the box end of the BIG wrench over the open end. This makes what you are pushing on longer, get it? Longer means more leverage. This amplifies the torque you can achieve. Think more moment arm.....
Ideally, a long breaker bar, the longer the better, to break it loose....
Hope that helpsContact me for information about Festiva Madness!
