I just bought a different ECU for my 91 festy and can't get it to run right. The MAF sensor is new and shows the proper reading values back to the ECU, yet it still throws the code for the MAF out of range. It's really getting to me cause you can't floor it and it runs so rich I'm only getting 35MPG and its causin misfires etc. I'm havin real problems and some input would be nice. I'm about ready to buy a new O2 sensor for it to, but I just really want to find the problem first. Thanks in advance for any advice.
I can't FIX IT @$@#$@!
How do you know the sensor value is correct? If it is measured at the sensor and not the ECU....it could be a wiring problem.
Vacuum leaks could cause a MAF fault code....Do you know the propane torch trick to locate a vacuum leak???? Works realy well!!!Joe Lutz
The SKATE ..... 1992L 5spd
I saw somebody else say something about that recently, so it does work, huh?Originally posted by jglutz View PostHow do you know the sensor value is correct? If it is measured at the sensor and not the ECU....it could be a wiring problem.
Who knew, I have always used carb cleaner and listen for it to die out.....
Kewl!Contact me for information about Festiva Madness!
I fixed it so if anybody has the same problems with this, I could help them before they go through what I did!"If you're not first you're last!" -Ricky Bobby
-91L "Oliver" Now B6DE swapped with an ATX Capri ECU on a MTX!!!!
The little Festy that could...and did!
(Gone on to a new life)
-90 Ford Bronco II Eddie Bauer
Some details as to what was wrong and how it was fixed would be nice to complete this thread!'93 Blue 5spd 230K(down for clutch and overall maintanence)
