Intake and Exhaust Seals are suposed to be diffrent, right? Because I have two packs of 4 and I cant tell which is which
Valve Stem Seals
Are they different....I would say not by dimension...the difference in valve stem diameter is about o.oo1o inches.
If the rubber is not different colors they are the same. Sometimes the elastomers are red and black. Red is silicone (hi temp) for the exhaust and black is buna-n for the intake.
If they are not labled in the package they should be interchangable.
I will run out to the garge later to see if I saved any....Click and Clack are on NOVA now....sorry...you'll have to wait until it's over...9PM EST.Joe Lutz
The SKATE ..... 1992L 5spd
Viton is really good....I'm not aware of any better elastomer.
Here's a pick...under close inspection, they appear to all be the same...if they were different, I would have saved them separately.
Don't ask me why I save these things...typically I look at or take my old parts when buying new to make sure they match.
Joe Lutz
Most after market kits are the same for exhaust/intake, the ones for the B6 i did were the same, and on the toyota engine i re-built they were the same. In the manual for both it said "factory seals may be different colors but after market seals are usually the same and are interchangeable".
btw joe... i still have the valve seals, rings, etc from the B6 i did a year ago... why, i have no idea. i should toss them out!~Nate
Current cars:
FOTY 2008 winner!
is this for B3 or B6? I just did my head a month ago and the 8 valve stem seals for the B3 are the same.
-Aspire brake swap COMPLETE!
if its not together yet, you could do a little polishing that exhaust side..Originally posted by scitzz View PostVery CLEAN!!!
Nice!!!
nothing like a clean engine i tell ya
makes me want to go re-build something again! not for anther two weeks though... then finals are over, and i have 2 engines and 2 trany's to rebuild. i can't wait
~Nate
Current cars:
FOTY 2008 winner!
Stefan seing the virgin head here's a little rebuiling trick....
Complete the engine less head...add all but one quart of oil.
Connect and run the starter to crank the engine until oil comes out of the block thru the port(s) to the head. A second or two after it bubbles out of the port(s) it will squirt to the ceiling, be carefull.
Install the head and pour the last quart of oil all over the valve trane before the valve cover is installed
Primed and ready to go.
Man alive....Stefan...keeping me busy tonite....i'm loving it
Joe Lutz
I'm not sure what you mean by virgin.. Its not new if thats what you mean.. this is what it looked like when I startedOriginally posted by jglutz View PostStefan seing the virgin head here's a little rebuiling trick....
Yea, I heard that before.. I guess using the starter would require attaching the block to the trans.. And theres that thing with the spyder gears... not sure if it would be a good idea to spin the trans w/o the axles in?Originally posted by jglutz View PostComplete the engine less head...add all but one quart of oil.
The way I heard it before was to use a big drill to turn it over
Originally posted by jglutz View PostMan alive....Stefan...keeping me busy tonite....i'm loving it:
Thanks for all your help!
89SX funtop! Fully loaded!
RIP 90LX
