am i forgetting anything...
  • am i forgetting anything...
    okay i'm just fixing alot of things... and well i thoguht i would do a full tuneup so far i got pcv valve fuel filter. oil change new oil filter. air filter looks about new. i really feel like i'm forgetting something...help me...
    1989
    Ford Festiva L
    Automatic
    ummmm....spark plugs , cap, rotor, wires........
      My tune up schedule
      Every 3 months:
      Oil
      Oil filter
      Tire Pressure - including spare
      Check all Lamps
      Every 5K Miles
      Rotate TIres
      Inspect Brake Pads and Shoes
      Inspect Brake Lines and Cylinders
      Inspect Suspention - TIe Rods
      Every Year
      Plugs
      Rotor
      Cap
      Wires
      T-stat & Gasket
      Belt(s)
      Fuel Filter
      Air Filter
      PCV
      Spray (Gumout) Throtle Body and Idle Circuit
      Check TIming and Idle
      Clean battery post and copper sieze
      Compression Test
      Vacuum Test
      Check Fuel Pressure
      Head Lamp Allignment.
      Lube Hinges and Latches
      Check TPS
      Wash Engine Compartment
      Every two Years
      Flush Cooling System & New Anti-Freeze
      U & L Radiator Hoses
      Heater Core Hoses
      New Tranny Fluid
      Pull Valve Cover and Inspect
      Every Three Years
      Wash Car
      Every Four Years
      Make list about body work.
      Throw out list about body work.
      Every Five Years
      Go thru all my boxes of good parts I've taken out of the car and think about all of the hungry people in the world....go out and buy a liter of gin.
      Joe Lutz
      The SKATE ..... 1992L 5spd
        This is where it gets Great! I love it!!!!!!
        Originally posted by jglutz View Post
        My tune up schedule
        Every Three Years
        Wash Car
        Every Four Years
        Every Five Years
        93 GL modyfied!!!
        :fish:
          and please, PLEASE, do NOT forget to check your blinker fluid! Most people don't realize how critical the stuff is, but changing it out every year or so will save you TONS of time and $ down the road.
          ~Nate
          Current cars:
          FOTY 2008 winner!
            I just love Joes posts!! And Nate, you forgot the muffler bearing, the cause of more broken homes................... or making sure to use only the finest filtered air for your tires!
            Michael
            Have owned 9 so far
              Most importantly don't forget to check the tension on the piston return springs!
              93 GL modyfied!!!
              :fish:
                When rotating your tires ALWAYS remember it's ok to switch front to back, but if you value your life NEVER switch left to right. (your car will flip several times the first time you go to turn it)
                P.S. Check your Halogen Fluid / Save lives.
                Steve GT
                  i love phoning up all the auto parts stores and asking for stupid parts, like new spark plugs for his dodge cummins or new valves for a rx7. it always makes me laugh.
                  Mike, AKA the sasquatch
                    man where can i get blinker fluid i think i'm out cause i have never checked it... thats a joke just to let you know i'm not that dumb... but no i mean the car was pre fuged before i bought it i found oil in the coolant. he said to keep the radiator oiled.. but i mean it was like chunks. i replaced the radiator.. but yeah i think i have a lifter sticking and i'm to afraid to open it up cause i know nothing about engines.. cause i am getting the sewing machine sound again... i'm hoping when i replace all that stuff it helps it out alot.. so far i did the oil change..and filter.. don't have a toruq wrench so didn't do the plugs. i really don't want to strip my head. i'm bad about over tightening.. so no plugs yet.. but yeah the rest is going to be done this weekend..
                    1989
                    Ford Festiva L
                    Automatic
                      My tune up schedule
                      Every 3 months:
                      Oil
                      Oil filter
                      Check all Lamps
                      Every 5K Miles
                      Rotate TIres
                      Every Year
                      Plugs
                      Rotor
                      Cap
                      Wires
                      T-stat & Gasket
                      Belt(s)
                      Fuel Filter
                      Air Filter
                      PCV
                      Compression Test
                      Vacuum Test
                      Check Fuel Pressure
                      Check TPS
                      Every two Years
                      Heater Core Hoses
                      New Tranny Fluid
                      Every Three Years
                      Wash Car
                      Every Four Years
                      Every Five Years
                      First, Joe, I might love you in a totally platonic, non gay way.........
                      Second, teh guy might need a hand, even if he drives and stops way too fast.....
                      You can easily do the plugs without overtightening. Just turn them till just barely hand tight, then do not go more than 1 1/2 turns past that. No torque wrench needed....
                        thanks i will do that.. and about the stopping way to fast you have to think my rear breaks are dead so it puts alot of stress on the front causing an considerable amount of wear..
                        1989
                        Ford Festiva L
                        Automatic
                          ^^you do not need a torque wrench for the plugs....snug them up and then a little tweak....thats a technical term...lol
                            scitzz....posted before mine...lol
                            "You can easily do the plugs without overtightening. Just turn them till just barely hand tight, then do not go more than 1 1/2 turns past that. No torque wrench needed...."
                            But 1 1/2 times after snug is way to tight...IMO
                              I thought about commenting regarding the need for a torque wrench to install spark plugs....then far be it from me to impede a trip to the hardware store and the acquisition of another tool.
                              And think about it....how are you suppose to learn that you really don't need that tool until you've purchased it.
                              Joe Lutz
