OK Darkdan , using available datasheets such as http://www.mobil.com/USA-English/Lub...erformance.asp or http://www.phillips66lubricants.com/TechData/index.htm how does someone determine suitability for an application, of in the case of semi or full synthetic oils whether they are true synthetics or in the case of semi's the percentage of synthetic oil... I live in a hot weather state and use 10-30 , usually semi synthetic , SAE SM ...
Is there a super secret site where you can see side by side comparisons??
