Axle Help!
This topic is closed.
  • Axle Help!
    Hi, I went to replace my axles today, everything seemed to come off of the car without a hitch. But when i went to reinstall the axle on the passenger side of the car it does not want to go back into the transmission. With a few taps it goes in a little ways, but will not seat inside of the transmission. Any ideas? The car is a 1991 Festiva w/ 5 speed manual transmission. The car is in neutral now but when i removed the axle it was in first gear (i did not know it was supposed to be in neutral), could this be a problem? Thanks -Conor
    Did you remove one, replace then remove the other? Or take both ut at once?
    1988 p.o.s. (228,000 and still going)
      hey thanks for the imput i only took one out at once. Also i was able to get it in, it just took some work thanks. Admin please lock thread
