remove it or not?
  • remove it or not?
    I will be swapping out the 4 spd for a 5 speed in my 89 Festiva and my only question is: Can I do it without taking the engine out? If anyone has done it either way pleaqse let me know, so I can make preperations
    thnx so much
    Ski
    Ski
    1986 Ferrari Testarossa
    2002 BMW 745i
    2002 BMW 325i
    1989 BP'd Festi :p
    I don't think there is any need to remove the engine.
    ~Scott
    1989 Festiva L EFI
    2010 Toyota Prius
      I removed the battery and the tray and it appears that there's room, but you never know?
      Ski
      Ski
      2002 BMW 745i
      2002 BMW 325i
      1989 BP'd Festi :p
        Are you trying to remove it from the top? I think generally people remove transmissions from underneath. There should be plenty of room to get it out without taking the engine out.
        ~Scott
        1989 Festiva L EFI
        2010 Toyota Prius
          Well, I was asking in general...I'm sure it it's easier from the bottom then thats where it'll go...
          Ski
          Ski
          2002 BMW 745i
          2002 BMW 325i
          1989 BP'd Festi :p
            yup...jack it up high enough to clear the car when you pull it out from under it and you should have it out in no time. they are pretty light.
              Awesome! That will save tons of work and headaches with remembering what goes where hahahah
              thnx again
              Ski
              Ski
              2002 BMW 745i
              2002 BMW 325i
              1989 BP'd Festi :p
                You should be able to do it without removing the engine. Good luck!
                Simon - pimptiva.com
                  All the way at the bottom of the forum index, is a section called other's articles, this is one of the articles in that section.
                  The Festiva Store
                    Nonamekid...that was exactly what I was looking for!!!!! Than
                    Skik you for the link
                    Ski
                    2002 BMW 745i
                    2002 BMW 325i
                    1989 BP'd Festi :p
                      I dont know why this huge typo above ????? But thnx again for the link
                      Ski
                      Ski
                      2002 BMW 745i
                      2002 BMW 325i
                      1989 BP'd Festi :p
                        Here to help, that section is often missed, maybe we should get it moved farther up...
                        The Festiva Store
