I put on 13 inch wheels and the tires rub in back. I was wondering what size to get that won't rub?
13in wheel rub
what size tires are you running?Originally posted by aschburner View PostI put on 13 inch wheels and the tires rub in back. I was wondering what size to get that won't rub?
what are your rims off of?Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
spacers also may help..
-Aspire brake swap COMPLETE!
I don't think spacers are the answer. The bigger the spacer, the longer the lug bolt will need to be, the more pressure gets added to them... So... you're going to invest a bunch of money into spacers and longer lug bolts.
What size tires are you running? What are the specs of the wheels (size, offset, etc)? I'd think about the cost of "making them work", vs. selling them and getting something that WILL work.
If you do chose spacers... I wouldn't suggest anything bigger than 10mm or so.Simon - pimptiva.com
