My little 88 L "Cherry Bomb" has a cylinder issue. When I rescued it, it was running on three cylinders. I narrowed it down to the # 3 cylinder that was not firing. When I replaced all four plugs, there was baked-on carbon all over the electrodes of the # 3 plug. I changed the wires, cap and rotor. It runs pretty good, especially on the highway. However, here's the mystery:
At idle and slow speeds, it is still running on three cylinders. The number three is getting spark and the plug is still clean. However when you pull the plug wire off the # 3, there is no change to the rough idle. It sparks from the wire to anywhere I place it on the engine, so I know the wire is good. If I pull any of the other three wires off the plugs, the engine fizzles.
Anybody have any idea what's happning?
Oh, I have driven it to work and back twice(45 miles each way) and on the highway at 70+ mph with no problems. In fact, it lives for the interstate.
