I was in the process a little while ago of assembling the new engine for the Silver Bullet. I discovered that there is a valve mounted on a bracket to the left rear of the carb (as looking forward) with a vacuum nipple broken off. It is connected by linkage to the carburetor right next to the throttle linkage.
The whole valve resmbles the EGR valve, but it has a plastic top with two vacuum nipples. I would post a photo, but I can't seem to do so on the threads well. The nipple that broke off faces to the rear.
Any idea what this is and:
a.) How easy is it to get a new one, or
b.) Can it be epoxied back together without clogging the hole.
Oh yeah, this is on the intake off my parts car. The original one is broken in the same spot, too.
