Seems a bit weird, but I'm no grease monkey and I'm afraid it could be the tranny ...
  • Seems a bit weird, but I'm no grease monkey and I'm afraid it could be the tranny ...
    I was driving last night and all of a sudden started hearing a noise. It sounded like high-frequency rattling or like when something spinning fast is occassionally making contact with something stationary (this is what concerns me the most; I immediately thought of the flywheel). At the same time, I noticed that the shifting got very sloppy. Sometimes it was hard to shift and other times, it shifted but felt like the stick wasn't all the way in gear.
    The rattling/contact noise is connected. If I put pressure anywhere (e.g. down, forward) on the stick, it reduces the noise. For the most part, it's not very loud. If I were listening to the radio (which is out right now), I probably wouldn't hear it. It intermittently goes away but is on most of the time. The engine isn't suffering and there's no discernable difference in performance or sound. Acceleration is fine. There doesn't seem to be anything wrong with the car other than that.
    I've got other things I need to fix on it and I'm afraid it might be indicative of an upcoming problem - something I really can't afford right now in time or money. The car is a 1988 Festiva L w/120K on it.
    Check the level of your tranny fluid.
      Your shifter did not come loose and fall down against the exhaust ??
      See if you can pull it back up into place .
      HD2500 Duramax Chevy
      Z28 LS1 power 500 +
        the shifter bushings may have worn out or the rubber bushing in the stabilizer bar going from the shifter to the transmission may be worn out also.
        1960 willys pickup
        1967 jeep cj5
        1988 festiva
        1989 festiva
        1990 festiva for parts
        1991 s-10
        "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!" —Benjamin Franklin, 1759
