automatic trans popping out of gear
  • automatic trans popping out of gear
    whenever i start the car and pull out of the driveway, when i get to the end of the driveway and stop to turn onto the street, it slips out of gear to neutral, but then its only for about 1-2 seconds, then goes back into gear. Whats up? Low fluid? I need to check the fluid level tonight. Is this a sign for a rebuild/new trans. I may be doing my manual swap sooner than later.
    -Aspire brake swap COMPLETE!
    It could be low fluid, the need to change the filter, or you might have some issues with the vacuum modulator. I'm assuming the Festiva has a vacuum modulator on the auto tranny. I know most other vehicles do.
    http://www.cardomain.com/id/hawkdoc60
    01 Chevy Impala 9C1 police package "Unnamed yet". 154K
    88 LX 5 speed "Silver PHOENIX" Currently being rebuilt inside and out. 400K
    88 L 4 speed "Cherry Bomb" saved from the car crusher just in time. 186K
    06 Ford F-150 Pickup Replacement for my 2001 Impala Cop Car that lunched its engine.
      my 91 does that and makes a grinding sound.
        my brothers 91 dodge spirit does that eventhough i changed trans filter and fluid and only does it when the transmision is cold
          Low fluid or maybe pump going bad.
          Renegade-Midwest Festiva Inc.Illinois Chapter
          99 Dodge Caravan SE
          95 Taurus SHO auto 265hp
          94 F150 351W auto (for sale)
          95 Honda 1500 Goldwing SE
          95 Iszuzu Trooper LS
            just changed the fluid and filter and so far no problems.....
