I was working on the Silver Bullet on Sunday and bolted up the 5 speed tranny I got from the junkyard. It was from a '90 Festy, but the housing was different enough from the old one interfere with installing it into the car. I pulled out the original 5 speed tranny with 400,000 miles on it and looked it over. The input shaft spins freely and if you pull on it, it has about a 1/4" of play going in and out. The junkyard tranny with ~160,000 miles was tighter spinning and there was no play in and out.
My questions are: Is the play in the input shaft too much? Should I even try using the old one as is, or should I swap components from one to the other so the old housing has the newer parts? Or should I just get a rebuild kit for the original?
I am eager to get the Silver Bullet backon the road and I keep running into these little problems, so I'm getting a little frustrated.
Thanks.
Thanks.
