I have a stock 93 5 speed. Around 11 today as I was going from one plant to the other, I got about half a mile and the car died. Check engine light was on when it died - Just lost power like the switch was turn off. I had just enough time to pull the distributor cap. Rotor was turning. (I was by myself so I could not check for spark or fuel (besides I had to hoof it down the road to get to a noon meeting)).
Question is - Has this happened to anyone else? Seems almost like either the ignition module or fuel pump. Can anybody tell me where the fuel pump relay is? Car was running very healthy up til now. I did notice a stumble this morning driving into work, but it didn't stall ???? Also when I pulled into my parking space this morning it seem to die - but then re-started later fine when I went to go to the other plant. All it is doing now is cranking?? Where is the ignition module located on this particular car? When I go back after work I want to be able to check it further any your information you can give me should help
Thanks in advance for any thoughts and help.
Royce
Royce
