well working on getting the whistling out of my car. Targeted at the ac pulley/crankshaft/camshaft area. dropped motor pulled ac pully off the crankshaft(?). In the process a head of 1 of the bolts rips off. Turn engine on, timing on the crank flys off (forgot to screw in bolts and 2screws. drop motor again, readjust the timing, and put back on bolts and screws(left the broken alone, just tighten the 2 screws and 3 other bolts. Turn engine on, 4got to tighten alt belt, no whistling but screeching like heck.
Arggggg back at it tomorrow.
the Good the Bad
-no whistling - spent 3 hours
-experience dropping motor - Broken bolt
The thing that I want to know is is it ok if i leave off the ac pulley thing because the car has no ac(pulled out)
And is it ok to just run the 3 bolts and 2 screws on the spacer for the crank or should i do more work and take the big bolt out and try to get the rest of the rounded bolt out?? Honestly im tired.
the Good the Bad
