Are there such things? Got new shoes and some decent junkyard drums on today and they're dragging a bit. They're getting pretty hot after a drive. I had to fight to get the drums on over the new shoes.
When I tightened the spindle nut, I tightened it down with a ratchet pretty tight, then backed it back off and then torqued it to 25ft-lbs. Is this incorrect? I could spin the wheel but it didnt keep spinning on its own for long. Maybe one turn at the most.
So is there any way to back the shoes off a little or do I just have to drive it for a while?
Also one other question. Should I be able to lock up the rears with the e-brake while moving? It seems pretty weak, and theres also a little slack in the rear cables. I tried adjusting the tension equalizer in the back but I think its already adjusted in as far as it can go. The adjuster on the handle just seems to put more tension on the handle. Doesnt effect the rear cables.
