I'm putting new rotors and pads on Festus. I have a Haynes ordered but it's not here yet. This is a stock 1988 Festiva.
I have the caliper off and apart. I have the axle nut off. I used a 30mm socket even though the nut is actually a 29mm.
The axle shaft slips in and out the splines about 3/8". The hub/rotor still spins on the bearings, but the hub will NOT seperate from the spindle. What do I need to do?
Thanks.
Thanks.
