HELP! Front hub and Rotor.
This topic is closed.
    But Just Amagine The Positive Camber!!!
      I used a broken hacksaw blade to scrape some of the rust off the pins. It's one of my favourite rust removing tools. Gets into tight places. Tape on one end of the broken blade makes a handle.
        My rotor is STUCK onto my hub (passenger side). I tried to SOAK the four 14mm bolts that hold the hub & rotor together with PB to remove them so I can seperate the hub & rotor but the bolts will NOT come loose!! They are now stripped to a 13mm size!! SOMEBODY PLEASE HELP!! Thanks!
          go to a wrecker's like pick n pull and tear the front spindles and hubs out of an aspire - slap em in and off to the races
