While doing other work on my 91 GL the parking brake froze. I took the right side apart today and took the whole adjuster assembly out. I could not get it un-stuck so I drilled out the pivot points and replaced them with stainless steel machine screws, washers, nylok nuts, and a little high temp grease. I also used my dremel tool to clean up the affected surfaces. This seems like an alright idea to me but I wanted to check with some of you to see what you think of the idea.
Thanks,
Rich Johnson
Wells, ME
Thanks,
Rich Johnson
Wells, ME
