So up until thursday I had been driving to work and running errands with the car. It was running absolutely wonderful. Then as I was driving to work thursday the car started to cut out, but with a little help from the right foot it would pick up again and keep running. Drove it home, checked the distributor - it was dry and in good repair. Drove it to work again the next day (about 15 km's) It was starting to stumble again more and more, until eventually the car stalled completely. After trying to turn it over a couple of times to no avail. Once I got to a safe spot (by pushing) at the side of the road I opened the hood and started thinking. I rattled the fuel filter a couple of times, turned the keys in the ignition and it fired right up.
So today I changed out the ORIGINAL fuel filter for a new one. The car started right up, but I noticed the it was idling really rough, and there is also a new loud ticking noise coming from the engine.It is not low on oil. I let the car idle for about 10 minutes. It tried to stall once but I caught it and gave it some gas. I turned the car off cleaned up my tools, went to start it for a test drive and low and behold it would crank but not start.
Can anybody help? - I've ceased working on the car due to complete frustration
Fuel pump? Injectors? EGR? I just don't know - I'm an apprentice plumber not a mechanic :sign3::sad3:
