When I turn my headlights on my car makes a beeping noise, the kind of beeping a car makes when the door is open or when keys are left in the ignition?? Any ideas???
Beeping noise
thats weird i don't really know but maybe the switch that says your key is still in broke and it's getting hit by that or something... i had a car once that when i changed the position of the wheel all the way down and back to where it was my brights would come on..
1989
Ford Festiva L
Automatic
2 of mine used to beep when i went around corners hard. then the beepy thing stopped beeping all together. i think maybe the wires come loose somewhere and random things will set it off. but i got lucky, and it fixed itself... or just broke completely, however you want to look at it.87 rx7
92L starsky and hutchstiva bp swap, aspire swap, side pipes(tranny swap on the way)
94 caddi deville
99 f250 LD 4x4 12 inch lift on 38s
i need more festies.
darn beeping
my 88 use to beep all the time and one day i moved the dome light switch to off instead of being on when the door opens and it stopped. weird definitely, but it stopped. Since it stopped i decided to leave it that way. Now my 93 was a different story. I ended up changing the steering column to get that one to stop. I figured the ignition switch was messed up.A Horse, A Horse my kingdom for a Horse. (well maybe just a rust free festy will do)
94 Aspire (waiting for a face lift thanks to a deer)
88 festiva (16 year olds ride)
93 festiva (my ride)
94 jeep yj (waiting for heart transplant)
94 cadillac sedan deville (the wife's ride)
You may need to check your door switches that operate the dome light. The doors may need adjustment and the switches are not compleatly dis engaging.1960 willys pickup
1967 jeep cj5
1988 festiva
1989 festiva
1990 festiva for parts
1991 s-10
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!" —Benjamin Franklin, 1759
