Will soon be replacing my clutch, gonna buy a whole new clutch assembly (as it's about just a cheap to buy the whole assembly here in Newfoundland) and seeming I have to take the engine out to do it, I might as well do it all at once.
Anyway, as I will be taking my motor out to do this, I'm thinking about turning this into a weekend job and replacing both cam and timing (front) seals as I know one is leaking and I'm probably going to replace the rear main seal as I think that's what my be causing my clutch to go.
I'm thinking about replacing the head gasket too.... I don't believe it needs to be done but if I got time, I figure I might do it for fun.....
Is there anything that I could do to my engine or watch for while I have it out, because it would be the most opportune time to do it.....
Also, does anyone have a full list of gaskets and seals that go on the engine, e.g. Valve cover, rear main bearing seal, thermostat housing seal, intakes, etc.....
Maybe someone could list them here....
BTW..... I only have a stock 1.3L Festy
