I'm trying to replace the timing belt and crank seal in my '88 carbed Festiva.
I have the alternator belt off, the water pump pulley off, and the outer crank pulley loose. I can't get the outer pulley out. It's hitting between the 'frame rail' and the crank bolt. My intent was to use an impact on the crank bolt.
I've tried to raise the rear of the motor using a floor jack. The whole front end of the car lifted without tilting the motor. Now I have a cherry picker arm chained to the rear of the motor, and it's lifting the whole front end.
A couple of people have suggested a wrench on the crank pulley, and then hit the key. I'd rather use an impact.
Any thoughts on why my motor isn't tilting in the mounts, like it seems to for others?
