Hey guys,
I'm going to replace my fuel lines as they are quite flaky. I replaced my brake lines last year, but never put them in the space where they're supposed to go as fear of breaking my fuel lines....so will do that while I'm at it (but enough of my short story)
But someone told me to replace them with all rubber hose, this doesn't sound like a good idea to me (and will probably be more expensive), but I don't know if it's safe.
Also, found the following from a link off a another post, does this sound right? BTW will just be replacing the copper lines and fittings, so does anyone know what size fittings they are?
The fuel supply and return lines on the 1989-93 Festiva w/MFI are both sized for 5/16" ID hose ( 8.0 mm ). The actual effective ID of the hard line is 5.7mm ( approximately 1/4" ), due to wall thickness of the metal tube.
he fuel tank vapor line is sized for 1/4" ID hose ( 6.5 mm ). The actual effective ID of the hard line is 4.8mm ( approximately 3/16" ), due to wall thickness of the metal tube.
