cross between clunk and clink
  • cross between clunk and clink
    hey, sometime when i accelerate (rarely) or shift to second (often) and ride over a bump or brake (rarely) the front end of the car makes a like clunk/clink kinda noise.
    I know this isnt very accurate but i don't have much to go on either :S
    Appreciate any help,
    Thanks
    Proud owner of 92L, 350KM, Home made muffler, sounds like a truck! 16 years without replacement of anything but filters! 5spd EFI, Anyone else's shifter look like its from a quarter-ton?
    ball joint or cv joint most likely. it it happens more while turning one direction its a cv
      yep, same thing happened to me and i changed ball joints and clunk went away. course could be cv or tie rod end also. check strut too and make sure bolts are tight
      Thom-Lifes too short, don't blink
      93 Festiva (Little Red Truck)
      01 F-150 (Big Red Truck)
        Could be a broken strut mount or a broken tranny mount. Just some more ideas.
        93 GL modyfied!!!
        :fish:
          Most likely....front sway bar...where it mounts to the lower control arm...both the arm and/or bushings are shot.
          I agree with the tranny/engine mounts.
          Strut....i don't know....when they are bad....they are bad in many driving conditions
          Joe Lutz
          The SKATE ..... 1992L 5spd
            I would say front sway bar bushings are worn out or gone. I had a similar problem. When accelerating it pulled to one side and when I left of the pedal the car would swerve to one side. Took me a little while to figure it out but when I finally looked at the bushings....it was completly gone on one side and clunked up a storm.
              Mine had more clunk than clink. It it was the transmission saddle (?) resting on the sway bar. The cross-member rusted away where the two front bolts go into the cross-member.
                AHHHHHH yes....I forgot about that one too....also had that on mine.....did make that clunk noise from time to time depending on how hard I drove it.
                  I recently changed out a ball joint on one of my Festivas. I replaced the one that was on there with another used one that "felt" tighter. After I put the "new" used one on there, you can hear a noise like a "clink" or a "clunk" while driving down a rough surface paved road. I think it's the "new" used ball joint I stuck in there.
                  Somebody mentioned it could be a strut seat but I never fooled with that.
                    Take it to a alinement shop. Let them tell you what needs replacement.
                    David
