Would there be any problems associated with taking a 5 speed out of a 93 Festy and replacing it with a 4 speed? I can't think of any myself but I'm deferring to those of you that would be more knowledgeable than I. The change was made because the 5 went bad and the 4 was available.
Changing the Transmission Question
Nope, direct swap, the only problem is that you will keep trying to get it in 5th.... LOL....Originally posted by BigWheel View PostWould there be any problems associated with taking a 5 speed out of a 93 Festy and replacing it with a 4 speed? I can't think of any myself but I'm deferring to those of you that would be more knowledgeable than I. The change was made because the 5 went bad and the 4 was available.Have had 6 Festys... and counting...
My Website:
http://www.StanfordMotorSports.com
Car Domain:
http://www.cardomain.com/id/Quaddawg
My Garage Page:
http://www.fordfestiva.com/forums/vb...o=view&id=6724
I had to do that a while back when the inout shaft bearing went bad on my 5 speed. I got a 4 speed off of CarbonVmax (from this forum) and used it until I repaired the 5 speed. The biggest problem is continually trying to shift into 5th gear. Took me a week to stop doing that. Everything else is the same.
Except you will have an extra sensor on the 4 spd trans for the shift light. Ignore it, and it is a direct fit.
MichaelHave owned 9 so far
