my festiva don't make heat , it blows out the top kinda warm but the vents is nothing , is this normal ? is there something i can do ? i would atleast like it to defog the window ? thanks for all your help
heater problems
replace the thermostat
replace the thermostat with the correct Ford part - search the threads for the PNOriginally posted by the816skeet View Postmy festiva don't make heat , it blows out the top kinda warm but the vents is nothing , is this normal ? is there something i can do ? i would atleast like it to defog the window ? thanks for all your help
From flow diagram in the book, there are two trap doors operated by the mode select lever. One is the the vent door. The other is the blend-air door. Both need to be half open for bi-level flow. I've never had my nose in there and I'm only looking at the diagram, but could it be that a linkage or lever is out of adjustment?
Dash vents blow outside temp, or A/C only! That is just the way it is. Also, in the winter, block off the dash vents,(I use two small chunks of foam rubber) by removing the radio bezel, and blocking the outlets to keep the cold air out. Don't forget them come Springtime.
MichaelHave owned 9 so far
^^agreed...I stuff paper towels in mine. I hate the cold air blowing through in the winter. You may want to block off the radiator in the winter also....helps with the heat situation, even when you have the proper thermostat and fully functioning system."FLTG4LIFE" @FINALLEVEL , "PBH"
