Help!!!!
  • Help!!!!
    the other day driving home from shool my altenator went out so i replaced it but when I went to start there was nothing there.I'm not get any juice or activity an put a new battery in. I checked all of my fuses and they have power.an ysuggestions on how to get it running again?
    Did you check the center fusable link under the hood on the driver side strut tower?
      yes I did
        Did you check that they all had continuity?
          we checked that there waspower on sides
            could be ecu when my alt went it spiked and blew my ecu, radio, drl module, and headlights. I did some searching and apperently it will blow whatever is on at the time it spikes. I have been a Ford tech for 23 years and have only seen this 3 times. But might be your problem. Ceck your power outputs to your injectors for power that is usually a good indication.
            Anything for a Festiva:thumbup::thumbright:
              well my lights works so I have power to them but ill check that.Its just I turn the key and nothing is there.Its really confusing me.
                my alternator full fielded and the voltage spiked and fried my ecu i had it bp swaped and used the escort harness and didnt wire in a fuse. i still had the festiva ecu in and it burnt up as well it didnt burn the fuse link either but still burnt the stock ecu. did you smell electrical burning? my radio worked and it still cranked but no start.
                YOU WILL HEINZ 57!!!!
                  can you short the starter motor and get it to crank? I forget right now how to wire it up but when I check the compression I clip a remote starter button to the starter so I don't have to be in the car to crank it over.
