What in the heck is this?!
  • What in the heck is this?!
    When looking at the motor from the front of the car....the part on the right side of the air cleaner.....that the 2 90 degree hoses go to. What is that?!
    do you have a/c?
    Joey Richard Jr.
    1991 Ford Festiva L; died but donated all her organs
    1988 Ford Festiva LX; EFI swapped in...actually everything swapped in
    Quality is Job 1. Together, We Can Save Lives. Ford.
      wait or do you mean the big plastic thing on top the valve cover?
      Joey Richard Jr.
        Yup
          yup to which one
          Joey Richard Jr.
            I took the side panel off that the hoses go to. On the left side theres a pile of broken up crap and on the right side theres a P-Nut.....could this cause problems? ha.....Also, should I clean the 2 filter looking things that go there? And the hose that comes from the valve cover to the air cleaner....that little filter there is drenched in oil. Does anyone sell replacements? Is it supposed to have oil all over it? Sorry for all the questions!
              Car has a/c....i'm talking about the metal part attached to the side of the air cleaner that the 2 90 degree hoses hook up to.
                you have a carbed, right? cause this doesn't sound very familiar to my efi...
                i know the intake tubes are built different with different stuff hooked up...
                yah think we're in two different worlds here.
                Joey Richard Jr.
                  its like an air pump egr thing emissions crap, cat over temp protection, one goes to the exhaust into the cat and the other i think goes to the exhaust manifold. if you unhook em you can hear the exhaust sounds throaty. i ripped mine off and plugged them. i didnt notice a difference. but i would just get some air cleaner foam and replace the filter and clean it.
                  YOU WILL HEINZ 57!!!!
                    Yea, its carbed. Ketchup, what you mean by air cleaner foam?
                      whoa!!! that's your pulse A.I.R. box. it feeds extra O2 to your cat so that the second stage works properly. it's for emissions and unless you remove the cat, removing those hoses will destroy the cat and cause the engine to run like CRAP.
                      Ketchup, you better put that stuff back on or remove the cat. if not, you'll regret it later.
                        I use the air cleaner foam that lawn mowers use. Just use a knife or scissors to cut a piece out. There is enough to make many of them.
                        1960 willys pickup
                        1967 jeep cj5
                        1988 festiva
                        1989 festiva
                        1990 festiva for parts
                        1991 s-10
                          So could the pile of crap in one side and p-nut in the other of that piece on the side of the air cleaner cause any problems?
                            They are part of the emmission system.
                            93 GL modyfied!!!
                            :fish:
                              i'm sorry, but what is a p-nut?
                              if you can post pics pointing to the parts that you have questions about, i can help more effectivly.
