When looking at the motor from the front of the car....the part on the right side of the air cleaner.....that the 2 90 degree hoses go to. What is that?!
What in the heck is this?!
I took the side panel off that the hoses go to. On the left side theres a pile of broken up crap and on the right side theres a P-Nut.....could this cause problems? ha.....Also, should I clean the 2 filter looking things that go there? And the hose that comes from the valve cover to the air cleaner....that little filter there is drenched in oil. Does anyone sell replacements? Is it supposed to have oil all over it? Sorry for all the questions!
you have a carbed, right? cause this doesn't sound very familiar to my efi...
i know the intake tubes are built different with different stuff hooked up...
yah think we're in two different worlds here.Joey Richard Jr.
1991 Ford Festiva L; died but donated all her organs
1988 Ford Festiva LX; EFI swapped in...actually everything swapped in
Quality is Job 1. Together, We Can Save Lives. Ford.
its like an air pump egr thing emissions crap, cat over temp protection, one goes to the exhaust into the cat and the other i think goes to the exhaust manifold. if you unhook em you can hear the exhaust sounds throaty. i ripped mine off and plugged them. i didnt notice a difference. but i would just get some air cleaner foam and replace the filter and clean it.YOU WILL HEINZ 57!!!!
whoa!!! that's your pulse A.I.R. box. it feeds extra O2 to your cat so that the second stage works properly. it's for emissions and unless you remove the cat, removing those hoses will destroy the cat and cause the engine to run like CRAP.
Ketchup, you better put that stuff back on or remove the cat. if not, you'll regret it later.Trees aren't kind to me...
I use the air cleaner foam that lawn mowers use. Just use a knife or scissors to cut a piece out. There is enough to make many of them.1960 willys pickup
1967 jeep cj5
1988 festiva
1989 festiva
1990 festiva for parts
1991 s-10
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!" —Benjamin Franklin, 1759
i'm sorry, but what is a p-nut?
if you can post pics pointing to the parts that you have questions about, i can help more effectivly.Trees aren't kind to me...
