caster/camber bolts
  • caster/camber bolts
    I am lowering my Festy. I plan on taking it in for an alignment when im thru and i have a set of the Caster/Camber bolts. My question is whether i should go ahead and put them in while im reassembling, and if so do they go in the top, or lower bolt holes.
    Thanks
    Jeff
    89 LX 5 spd, AC, Lowered, Tint and Black Primer
    230,000+ miles.
    My car is lowered and I did not need them. It seems like some cars need them while others do not.
    93 GL modyfied!!!
    :fish:
      My B6T car has camber bolts and if i remember right they're in the lower holes, but i also have coil-overs made for a VW
        Thanks for the help guys.
        Jeff
        230,000+ miles.
          camber bolts are to be placed in the UPPER holes.
          i also have a lowered festy and didn't need the kit. granted i'm at 1.2 deg neg. camber, but it's even left to right and that's the important part, it needs to be even within .3 degrees lef to right.
            do you need them for the front and the rear or just for the front
            ccasion5:
              The only way to change rear camber is to shim the hubs.
              OX SMASH!!
                I have them as well, only I thought they were top mounted?
                  specify upper holes.. i am looking at getting camber bolts and they are 2 17mm bolts that attach the bottom of the strut to the hub.... are these the upper bolts you mention? whats the difference between camber bolts and camber wedges?
                  -Aspire brake swap COMPLETE!
