Blown Fuse?
  • Blown Fuse?
    I was installing a radio in my car last night and had to stop due a blown fuse on the constant +12v line(not the switched line). This morning, the car will not shift out of park. Are the soleniod for the shift lock and radio on the same fuse?? Seems like a coincidence. I was looking at an electrical diagram last night and the fuse should be either the cigarette lighter or the interior fuse.
    1993 Festiva GL
    new fuel pump
    97 B3 swapped in by Eurotiva
    no shift lock solenoid that I know of....could be wrong. But I know I can run through the gears easily without the car running or even a key in the ignition. Thats even without pushing the clutch in.
      if he's stuck in "park", that should be an automatic.
      but i think those shiftlocks are done with a cable, no electronic.
      Joey Richard Jr.
      1991 Ford Festiva L; died but donated all her organs
      1988 Ford Festiva LX; EFI swapped in...actually everything swapped in
      Quality is Job 1. Together, We Can Save Lives. Ford.
        ahhh....was not paying attention....sorry....I also have an auto though and I know that even if there is no power it shifts out of park.
          i dunno either. all i've got is a 5 speed! muuucch more fun.
          Joey Richard Jr.
            The shiftlock in my '93 L is an electric solenoid, well at least it was before I ripped it out in frustration after getting stuck in park a few times.
            EDIT: Come to think of it, the first time was when I had a dead battery and I was stuck in a narrow driveway between two houses and couldn't boost it, and the second time was when I was changing out the radio. Didn't know it at the time, but the radio wasn't "dead" like I thought, it was actually the power line filter running to it that was shot (black plastic block tucked in behind the lighter).
              Oh, okay. I've only ever seen a Mitsu Mirage taken apart because of a similar problem...there was a cable going from the brake pedal to the shifter, so you can't shift out of park or into reverse without pressing the pedal. But I don't know what's there for when you start it...
              Joey Richard Jr.
                the old 90 LX i used to have was auto and it had a "shift-lock" as well, although i never had to repair it
                  It was the "Room" fuse 10A. It's labelled "Room" on the fuse panel, I think it is called the "Interior" fuse in the Hayne's. Popped in the fuse and it shifted no problem.
                  1993 Festiva GL
                  new fuel pump
