i read on here a while ago that someone had a problem with their car stalling imediately after starting,they heard a click under the dash from under the steering column somewhere,and then it won't restart until you turn the key off all the way as if to reset something and then it would start again but die within 5 seconds ,i can do this all day long,it will start ,but click then dies.89 L carb. 5 speed. any ideas or links to that thread would help. thanks
mystery
i have the same "click" but it kicks up my idle (usualy). i havn't found a solution to that yet, but it only happens in Scrappy, Boo doesn't "click". i'll check my factory amnual again and see what i come up with.Trees aren't kind to me...
On my 88 carbed, when mine clicks, it sounds like a relay, my idle drops. Only happens on cold starts. In 80 to 90 degree weather, it clicks within a quarter of a mile of driving. 50 to 80 degrees, about one mile. Below 50 and lower any where from one mile to a mile and a half.
I believe it has something to do with the choke.1960 willys pickup
1967 jeep cj5
1988 festiva
1989 festiva
1990 festiva for parts
1991 s-10
it is the h300 relay under the dash which controls the electric choke i believe.i removed it and it ran fine,took it apart and the wire was broken inside.now i'm not sure if the choke is bad as well, i still need to check that out too.but it runs great right now without the ralay.and it was around 40 degrees this morning when i started it.not sure how it will be when it gets really cold,but i'm replacing it anyway.so the click was definatly that relay,and it would kill the engine every time unless i was on the gas.
