Does the rear of the Festiva need to be aligned? I'm going to put new shocks and mounts on the back so I can out my new tires on. Also, would it be safe to drive this thing with the steering wheel shaking for about 30 miles? Or will it mess up all my new front end parts? Thanks!
Rear Alignment
1. no
2. yes
3. no, just take it easy.Last edited by Levitan; 10-20-2008, 11:34 AM.ENFORCER - Midwest Festiva Inc., Iowa
#2 .....Cheesehead
#3 '91 White - Donor Car
#4 .....Montana Project
SOLD----Levistiva for $1500
Bought her back for $450
Just a note.
The rear doesn't generally need alignment, but can be aligned using shims.
Usually not necessary, unless it has been hit in the rear.
Just watch for odd tire wear in rear tires.'93 Blue 5spd 230K(down for clutch and overall maintanence)
yeah more then likely if you see choppy its cause the shocks are bad so replacing them would help a lot and probably where ur getting vibration from too, it doesn't technically need to be aligned, but might as well have them check the alignment on the rear too while they have it. I know at pepboys the machine they have checks the alignment of the whole car, so they would let u know, and when u get it done make sure that they show you the before and after specs(GONE)88 Festiva LX 5 Speed, Factory A/C, Factory Tow Hitch, Tach.
95k Original miles
New: Tires, Axels, Front Wheel Bearings, Fuel Pump, Valve Cover Gasket, Carb Rebuild, Timing Set, Belts, Shoes, Distributor, CapRotor, Wires, Plugs, Coil, Grant 11" Steering Wheel, 3700 Watt Stereo System-6 1/2 Infinity speakers, Infinity tweeters, Almani 12" subs
Correct about the "choppy", that too is my understanding.
However, I'm unsure of the mechanism that produces that pattern in the tire.
Alignment issues generally produce a complete removal of tread in a specific area!
Or at least accelerated wear in a localized area of the tire.'93 Blue 5spd 230K(down for clutch and overall maintanence)
if you're seeing cupping of the rear tires, replace your rear wheel bearings, even if they look and feel OK. Trust me, been down this road several times before. Most of my customers didn't believe me at first either...
Jim DeAngelis
