Just got my Festiva back on the road recently after 5 years. Car runs perfectly until it hits half a tank of gas at that point in hesitates mid throttle car does not stall and continues to idle perfectly problem persists until gas tank is filled back up. This is a 92 Festiva with a 5 speed. So far I have replaced the fuel pump,fuel pressure regulator,throttle position sensor and the fuel filter. When I had the fuel pump out the gas gauge read half and there appeared to be half a tank of gas in the tank so I think I ruled out a faulty fuel sending unit. Please help I would like to be able to run closer to empty.
Festiva hesitates at half a tank of gas
I have a sortof similar problem on my minibike... there is a hole in the pickup line so that after about 1/2 tank it starts sucking air.
On the festy with the pump in the tank, you don't have to worry about the pickup, but I'd check the high pressure line from the pump. I'm betting like Brian said it could have a small hole in it, and after about 1/2 tank its spraying fuel back into the tank, still flowing enough fuel for it to sustain an idle but not enough to take it above that. Have you checked fuel pressure? that seems like the first and most obvious thing to do; before you replace anything that you have already mentioned. Check it with a full tank, and then after it starts bogging, under a variety of loads. See if the pressure when its running fine differs from the pressure when its not running fine, then go from there.~Nate
Current cars:
FOTY 2008 winner!
Just a quick test.....disconect the canister purge solenoid electrical connector next time the car mis-behaves. I'm wondering if some type of goofy vacuum leak is created below 1/2 tank? Just a gues and a start.
Or...check the fuel pump assembly....stem may have a crack or leak such that below 1/2 a tank...the fuel pump is sucking air.Joe Lutz
The SKATE ..... 1992L 5spd
pump is sucking air. Pull the pump assembly and inspect it closely for leaks. Common issue on many different cars.Jim DeAngelis
kittens give Morbo gas!!
When I replaced the fuel pump I used the assembly (screen and pick up tube) from another car unless there is the same problem on both pick up tubes I think that is ruled out? Does anyone sell a new fuel pick up assembly not the pump just the bracket and tube? I believe you all may be on to something. It is difficult replacing used parts with used parts. Thank you everyone for your help.
Hello other Festiva owners new to this forum.
I have a 1990 festiva that is doing this also, after it gets down to a half a tank it runs like crap, I have two other festiva cars one is used for parts, and I've changed alot of stuff to get it to run right but can't seem to find the problem.
Things that I've changed:
1.The whole fuel pump assy.
2. fuel filter
3.Dist.
4.coil
5.spark plug wires.
6.exhaust front to back (all)
I NEED HELP PLEASE!!!
Have you changed anything lately? I'm thinking of looking at the hose that goes to the fuel pump to the fuel filter and see if that is bad maybe have a pin hole in it.....?Originally posted by tholliday75 View PostWell at least I don't feel like I am crazy now, nascarjunkie best of luck to you I just have to keep it above half a tank to run right but I am not giving up yet. Keep you posted.
if you're still having problems with it by next week, let me know and i'll roll out your way and see if we can't fix it. i'm about 1h20min away.Trees aren't kind to me...
I think you live more than a couple hrs. away...........:pOriginally posted by FestYboy View Postif you're still having problems with it by next week, let me know and i'll roll out your way and see if we can't fix it. i'm about 1h20min away.
I changed out the fuel pump from another car, do you really think that pump is back too???
