I have an 88LX that has a non-working temp gauge. I replaced the T-stat yesterday with a Ford OEM (2 stage) t-stat and still no change. I also recently flushed the rad and put in new coolant and a new cap as well.
I get heat in the car which is nice but I'd like to be able to see where the temp is at.
There is a sensor on the T-Stat housing. Is the the water temp sensor? If so is there a test to see if it's good? I read somewhere in my search that you could do an Ohm test??? (Not really sure what this is or how to do it. Can anyone clarify?
TIA
TIA
