Now that I have my Festy running like a top I have a new oil leak. The car is not leaking when sitting/not running. Only leaks when running on the passenger side and loosing a lot of oil. I suspected the pan gasket but that doesn't appear to be the problem. After crawling under the car the oil seems to be coming from somewhere around where the timing belt sits. I'm thinking some sort of seal but not sure how to get to it. I checked earlier forums and see nothing. Any ideas of what the problem is and how difficult to fix?
New Oil Leak????
clean the area good to make sure thats where it is from. crank / cam seal likely as stated.
-Aspire brake swap COMPLETE!
The bottom half of my engine is caked with crud. Cleaning I can do but what's the best way to get a good view of these two seals? I can't see much from above or below with the car running. Is removing the wheel with the car on jacks (car running) the best vantage point?Originally posted by ejp2fast View Postclean the area good to make sure thats where it is from. crank / cam seal likely as stated.'93 Festiva GL / "HOT ROD"
'02 F-150 Supercrew
'02 Excursion 4x4
'98 Jeep Cherokee Classic Limited
You won't be able to see the crank or cam seals until you remove the pulleys and the timing cover first. I had to loosen up my motor mount to drop the engine down far enough to get an impact wrench on the crank bolt. It is not an easy job unless you have done engine work before or have experience changing timing belts in my opinion.I'm going to come at you like a spider monkey!
White 1993 L plus, 5 speed - 47k miles
* Aspire brake swap, 14" Miata wheels & Tein coliover suspension
