Just bought a 1990 L. I'm having some electrical issues with it: sometimes the wipers/washer work and sometimes not. The column stalk is very floppy. Also, I have the same problem with the heater fan, and at the same time--if I don't have wipers, I don't have the fan. If I do have wipers, I also have the fan. I'm thinking there is a common ground that is shaky. Anyone else have experience with this? Thanks.
Electrical issues
Electrical issues
Tags: None
Sometimes my wipers don't come on. I have to jiggle the key in the ignition until they do. Putting a few drops of oil into the keyhole seems to cure the problem for a year or so.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Fixed!
Actually not the car, but my head, thanx to WmWatt's advice. Yep, that was it; seems that a weak spot in these cars is the ignition switch. But now I am armed with knowledge...
I also discovered that no warm air comes out of the center dash vent; only the lower vent and the defrost have warm air. Interesting "feature".90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
that is "normal" for these cars. vents are fresh air only.Trees aren't kind to me...
