Hey guys maybe you can help me out...intermittenly my festy has been smoking from what looks to be right around the radiator cap...It doesnt do it all the time but when it does its a lot of smoke any ideas??? thanks in advance
Smoking from radiator area
you may want to try a differant cap.....it may be going bad and starting to blow off a little before it actually should. Hopefully not a crack around the neck. Did you check the tube that runs from under the cap to the overflow bottle?"FLTG4LIFE" @FINALLEVEL , "PBH"
Could be overflow. I used to notice a bit of water vapour (not smoke) rising from the front of the hood when I stopped at home to open the garage door. Never did anything about it.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
