How do I tell if my injectors are pulsing? Did the B6T swap and am not sure if I have spark or fuel. I know how to check spark.
Injector help
Tags: None
you can get to the injector, disconnect the harness and check the resistance...
actually i'd try this first: try to start it, then take out one or all spark plugs and use a flashlight to see if the piston top is wet... if yes, likely injectors are working, if no, they are not.
once started, to make sure all the injectors are working, take a long screwdriver (or engine stethoscope) and listen for the ticking of each injector solenoid.
-Aspire brake swap COMPLETE!
