Has anyone ever ran into a wiper arm that has been torqued down on the pinion splines so tight that it will not pop loose? If i had some sort of mini gear puller it would be a piece of cake. But i don't. I did spray it about an hour ago but no luck so far. I thought about using heat but there's rubber and plastic involved. Any ideas? Thanks
Wiper arm angle all wrong and super tight
You can buy a cheapie battery cable puller at any Parts chain. Works just fine.Chuck
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
Got it. Turned it around to face the sun and soaked it again. Put pressure on the arm gave it a couple taps and it came off. ThanksIs that someone there ??? 1981 VW diesel pickup---1988.5 Suzuki Samurai tin top---1993 Festiva---1974 Bricklin SV-1 ( very thirsty basket case)---2003 Tracker(bells and whistles)
