Okay so a couple of weeks ago my car overheated after the radiator split and blew another headgasket.
I tore everything down the head was fine, and straight. I put in a new headgasket and I have 120 psi+ in all the cylinders. The car is idling ruff and only seems to be running on cylinder 1 + 4.
I am guessing this because while having the car running I pulled the spark plug wires one at a time from each cylinder and the car only ran ruffer on 1 + 4 (indicating they where running fine, where cylinder 2+3 had no effect when there plugs where removed...
I pulled the plugs and they look good, completely dry. I was wondering if this could mean a fuel issue?
Just looking for some ideas so Brian can buy my yellow beauty :-P
Logan
Logan
