I left the lights on in my Festiva this afternoon When I tried to jump start it (yes I had postive/negative correct) there wasa big spark. Turn out that there is a small box type thing (sorry about the technical terms) almost right behind the battery that hold 3 separate wire. Each side of the 3 wired plugs into the box, form 3 small loops. I burned one of these up & am not sure what it is; the car won't start without it. I have looked online, but can't seen to find anything that remotely looks like this to order the part. Any hekp would be greatly appreciated!!!
wiring ??
Several auto parts stores carry them, but not in a "wire loop" form (at least I haven't seen them this way). The ones in the parts stores look like little rectangular fuses and several folks on here just plug these into where the wires go. They aren't expensive.
I'm not totally certain about the amps (DC current) rating... 30 amps?? 50 amps??
Get some from j/y
here is a pic of what you should look for:
they are about $5 at autozone
I run a green 35amp? in the center and a pink 25amp? one on each side of it!
they don't look like they will fit from the picture, but they do.
btw, where are you at?Last edited by Ogrestiva; 12-09-2008, 11:13 PM.89' Maroon and black Festiva LX with a sunroof. :alien:
siperdoc.
Take a picture of the driver's side strut tower, from the same angle as your above picture, and post it. The box that the links are in is on the front of that tower.ENFORCER - Midwest Festiva Inc., Iowa
#2 .....Cheesehead
#3 '91 White - Donor Car
#4 .....Montana Project
SOLD----Levistiva for $1500
Bought her back for $450
Originally posted by Maxxsmama View PostThank you everyone for your help!
I am in Reno, Nv. - I think I am the only peson in Reno with a Festiva! I have a white 1991.Jim DeAngelis
kittens give Morbo gas!!
Originally posted by rcottle View PostHas anyone thought about converting to a fuse/relay bos that the new style fuse could just be plugged in? I need the whole contraption (sp) I have all my wires twisted together with an electrician wire nut..Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
