ok, i looked and there's no info on this so here goes:
i have two (2) festivas that have broken driver wiper arm mounts. it seems to be a relatively common issue but there are no fixes for it.
as i see it, it one were to attempt a fix, one would be required to seperate the spot welds of the upper cowl to gain access to the mount area in order to weld it back into place.
is there anyone out there with expierence with this issue?
note: the arms function properly, but because the mounts are broken, they can't properly clear the windshield.
