i put the hammer down today and when i pulled off my festy didnt. this happened about 6 months ago but i changed my pcv valve so im assuming its a vacuum problem. HELP!
Reoccuring problem
butterfly valve in the throttle body sticking? thats what it sounds like...
how often do you 'hammer it'? does it do it when you go easy on the throttle?
-Aspire brake swap COMPLETE!
Among the many things it could be, check the bellcrank / throttle cable at the carb, make sure the cable isn't kinked somewhere or routed weird to cause it to bind up, cable isn't rusted, have burrs/loose wire strands.
Focustiva: Because I was told it was was impossible to fit a Focus bumper on a Festiva.
In memory of Dean Allen - V8 Festiva 1955-2010
Every once in a while I get the car runinng along at 40 kph (35 mph) and push the pedal to the floor. The car should accellerate smoothly to 80 kph (50 mph). If not it's time for a tuneup, including carb cleaner.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
^^ yes x2!!! then lube the crap out of it.Trees aren't kind to me...
ok, this is what i figured so far. Last night i disconnected the carb plugs and battery. Today it ran fine, go figure. So i took off the air cleaner, started it, let it warm up, idle down. I started spraying carb cleaner on the vacuum lines and found that the line at the back of the carb was sucking air. what I'm gonna try to do is replace the lines and try to find a new abcv valve.
this better fix it for good.it'll do the 1/8 in 13.7, spin tires, and make all my drunk buddies giggle.
"I like a Festiva because there's less car to get in the way of the driving experience"
