well my speedo cable isnt lining up i think the dirt and stuff in the way and where the 10 mm bolt is the flange that attches to it broke off.....omg so now what????
help help help
Don't panic about the tab being broke off. It is actually kinda common. As long as the rubber o-ring on the gear is still good, it should stay in pretty tight.Originally posted by dragonslit View Postwell my speedo cable isnt lining up i think the dirt and shit in the way nad where the 10 mm bolt is the flange that attches to it broke off.....omg so now wat????http://www.cardomain.com/id/hawkdoc60
01 Chevy Impala 9C1 police package "Unnamed yet". 154K
88 LX 5 speed "Silver PHOENIX" Currently being rebuilt inside and out. 400K
88 L 4 speed "Cherry Bomb" saved from the car crusher just in time. 186K
06 Ford F-150 Pickup Replacement for my 2001 Impala Cop Car that lunched its engine.
It should be safe to drive to someone who might be able to help you in person. I'm sorry, it is hard to try and help by describing things.http://www.cardomain.com/id/hawkdoc60
I'll bet someone at the parts store might be able to help. It can be kinda tight to get in and out.http://www.cardomain.com/id/hawkdoc60
Yes, it should be fine.http://www.cardomain.com/id/hawkdoc60
Good luck.http://www.cardomain.com/id/hawkdoc60
Dragonslit, did you try wiggling the gear assembly from side to side and front to back while pulling? Also did you try rotating it while pulling? On my car it sticks and it takes some wiggling and rotating until it comes out suddenly - after I put it back in it can either come out easily or else sticks again, depending in its mood. It can appear frustrating at first but you can get it out easily.
